4870 1gb help
8 Feb 2007
Hey i recently purchased a HIS 4870 1gb . On idle the card is running at 70c is this normal because it seems to be very hot.
Also on age of conan i get issues with artifacts on the screen sometimes. I will upload some aritfacts later. i upgraded drivers to 9.2 this seem'd to reduce how often it occured but its still there.
Thanks Ethan
I've got a Sapphire HD4870 1GB and on default fan settings it runs happily on idle at about 45degrees. Not sure why yours is running so high, unless you've overclocked it? My settings are the GPU clock at 840mhz and the mem clock at 1000mhz.
