- 3 Jul 2008
I would dearly love to know what folk out there do to get the gains they are stating.
Try forcing it to use multi-GPU, rather than letting it select automatically.
To your crysis shortcut, add: +r_MultiGPU 1
eg, for the default install location, right click on the shortcut, go to properties, and change to:
C:\Program Files\Electronic Arts\Crytek\Crysis\Bin32\Crysis.exe +r_MultiGPU 1
Note though that proper multi-GPU support was not added until patch 1.1 (I think...), so if you're running just the demo version for the benchmark you won't see any improvement. I think there is a box in the benchmarking tool where you can add the r_MultiGPU=1 command also.
