ATI Radeon 4850/4870 mix and match with Radeon 3850/3870
http://www.tgdaily.com/content/view/38056/135/
Just keep in mind that these two cards need to include the same amount of memory. If you mix and match a 3850 with 256 MB of memory with a 4850 512 MB, the 4850 card will default to 256 MB. If you wonder whether you will be able to combine a 3870 X2 card with a 4850 board, our sources indicated that this scenario should work as well.
because crossfire (used to be im not sure if it still is) is like SLI, cards need to be identical, not same manufacturer but same GPU, etc. little analogy, you bought yourself a nice new card your putting 17'' wheels on one side and 20'' on the other, doesn't work does it? im expecting 'fail' for that![]()
shame NVIDIA haven't noticed that crossfire actually works and updated SLI to compete![]()
only thing was the memory size goes to the lower card memory
