4870 Rivatuner temps
28 Dec 2003
Ok, got Rivatuner monitoring temps on my 4870 while I give it some stick. Odd thing is that RT is reporting four temperature readinds:
Core
Core \ display IO
Core \ memory IO
Core \ shader core
Whilst the main core temp is reaching about 75C under load and the display one reads much the same, the shader core one is higher and the memory one higher still, peaking at 95C
Are these temps all accurate and normal?
