A wee while back i was going for a 24" monitor and had planned to use my 4850 512mb on it, that had to be put on hold for a while due to money. Now that plan is back in action, but with a couple of other upgrades in mind due to the 4850 performing well but not as well as i'd hoped even at 1600x1200, so i have a couple of questions.
First off, is the 4870x2 2GB actually 2 cards in one or a single card with dual gpus? The reason for this question is i'd like good performance across the board but am hesitant in case games only fully utilize the card if they can already utilize crossfire.
Secondly, power supply. Currently i use a Corsair 520W PSU. I understand this won't be meaty enough for the card i have in mind so need some suggestions as to how much more power i would need. I had in mind changing to the 620W Corsair to cover the extra requirements from the upgrade, will this be sufficient?
And lastly, i'm still on a Gigabyte DS3 motherboard with an E6850 CPU overclocked. Will this combo hamper the 4870 at all or is it worth upgrading to a newer motherboard or even a newer motherboard+CPU? If so then how much of a difference would it actually make, i'd rather save that part of the upgrade until a couple of months down the line so i don't have to be careful about what i'm spending on the GPU, PSU and monitor, but can add them into this upgrade if the difference would be noticeable.
The reason for considering the 4870x2 over the gtx 295 is price, i can find it significantly cheaper than the nvidia card elsewhere other than OCUK.
