1) Elastic band is used as i didn't have any cable ties to hand at 3 a.m.
2) I need a 2nd 92mm fan ideally as one 1300rpm 92mm fan is only just good enough.
3) Cables need to be sorted, just with swapping cards every day I haven't got round
to it.. it used to be so neat.
4) 4870x2 at 100% is bloody loud lol. MSI Afterburner won't allow proper control
over the fan profile for some reason, any ideas?
5) The heatsink cowling (not in picture!!) isn't mine so I can't hack it up
otherwise I would make two discreet holes in it.
6) Temps in Battle Field BC2 didn't get above 60C amazingly. Core usage was 100%
core 1, around 50% core 2.
7) I didn't have the X-brackets/braces for the rear of the GPU's I had to use 2x red
motherboard washers, a cut bit of copper and the original screws. I didn't have
enough washers, so the heatsinks are only held on by 2 screws each rather than 4
lol. Really need to get that sorted with proper washers (or X-Brackets asap).
8) Running 10.5 drivers, should really get 10.5a though. Is there a hot fix for it rather than getting the full install?
If anyone has spare X-brackets for a 4870X2 obviously let me know (often you won't
use them if you went and watercooled your card).
Sorry for quality of pictures, I took them using my TG01 which has a naff camera in
low light conditions.
