4870x2 ek waterblock
14 May 2008
Hi guys, can i fit barbs to either side of the waterblock??? (EK Waterblock) Ive followed the instructions but the current configuration makes for a very tight bend when routing the tubing.
If i could enter the water block from the opposite side then it would make for an easier water flow...
System isnt up yet, just waiting for second waterblock which will be used in crossfire..
Should arrive tommorow and should all be up and running by the weekend... Ill post here my observations in the coming days
