Been using a Sapphire 4870X2 for a few weeks now without issue in my system which is powered off a FSP Epsilon 700W PSU. Since this PSU doesn't have a 8-pin PCI-E adaptor I've been using a 6-pin PCI-E to 8-pin PCI-E converter that I sourced.
Everything was running fine until I just tried to boot my PC now, and it gets stuck as soon as it boots on a screen telling me:
"YOU HAVE NOT CONNECTED ONE OF YOUR VIDEO CARD POWER CONNECTORS TO THE POWER SUPPLY. PLEASE REFER TO THE 'GETTING STARTED GUIDE' FOR PROPER HARDWARE INSTALLATION'
..with my PC making a constant beep-beep-beep sound. I have tried to reboot it several times, disconnecting the power completely, etc - nothing worked.
I haven't changed anything or added any hardware between it running one minute and not running the next so there is no additional power drain. For reference the PSU is powering a single 4870X2, C2D overclocked to 4-4.3Ghz, 4GB of RAM, 2 WD Raptors, 1 WD 1TB drive, DVDRW and 3 fans.
I finally managed to get it to boot just now by disconnecting the two 80mm fans at the front of my case, but I'm concerned that the PSU is on its way out?
Anyone have any thoughts or experiences?
