4880K OC using TurboV Evo
30 Mar 2014
Hi 8 Pack,
I am a newbie in this Oc game and really need some suggestion. I used Asus TurboV Evo to auto overclock my system (i7 4820K) and got 25% performance increase from 3.7 to 4.6 (I want 4.8) which is helping the frame rate quite a bit, but my concern is CPU is drawing 1.44 V and the base clock and multiplier is fluctuating quite a bit (base clock: between 1445 - 2745, mutiplyer: between 12 - 22) is it safe to carry on like this or should I manually overclock it? Temp is quite stable, I was getting 35 C (47 highest) on an average with Cooler Maser liquid cooling.
Also I am using 2 x 8gb Kingstone beast 2400Ghz but I am only getting 1600 Ghz out of it. RAMs are drawing around 1.66 V which is within the manufacturer's stated safety limit but how can I get more performance out of it.
I would really appreciate your help.
Many thanks,
Ronnie
