49” 4K living room
23 Oct 2012
Looking to upgrade my 43” FHD tv with a 49” 4K unit.
The reviews for the Sony KD49XF9005 look great but looks like it’s been discontinued :(
Budget of 1k ideally.
Any other suggestions?
Would recommend the 49 inch Sony xf9005 if you can get your hands on one. I have it in my gaming room and it's brilliant despite being used to an of oled in the living room.
Get the Sony BRAVIA KD55XF9005BU £949 with 6 year warranty.
https://www.richersounds.com/tv-projectors/all-tvs/sony-kd55xf9005bu.html
It has a true 10bit panel the 55" and up, the 49" versions only have 8bit+2bit FRC. Same with the 49" XF9005 and XG9005 and the XG is £1099 which is silly and same TV as the XF9 49" before it and only a new remote.
The 55" won't be much bigger physically than a old style FHD TV with big chassis and large frames, but more viewing screen space. Check your measurements for the area you want to place it with the specs page, it list the dimensions.
Thanks for the input guys.
Popped into my local electronics store and saw the new model: KD-49XG90
Looks very impressive!
