- 4 Dec 2012
Decided to do some overclocking yesterday and managed to get 4.5Ghz on a vcore of 1.210 idle temps are 30c max, and full loads temps are 65c max, this is using manual vcore and not offset, just wanted to know if its safe to run my pc at this vcore all the time? I think the stock vcore for a 4930k is 1.060v so there is not much difference, the reason I'm asking this question is because I don't really know how to use offset? I know what it does but just don't understand how to use it even though I have read forums and stuff just cant get my head round it, if you guys have any idea how to use it your knowledge would be welcome, but if i cant get offset working and the vcore manually is unsafe, I'll just use stock settings, hope you guys can help, thanks
System specs
RIVE
4930k
DP 1866MHz
H100i CPU cooler
System specs
RIVE
4930k
DP 1866MHz
H100i CPU cooler
