Hello, i'm just looking to find out if anyone knows roughly the correct temps for a 4970k on stock volts(1.2 for me) using the stock cooler, preferably one thats been delidded.
I recently started getting very high CPU temps so i had to drop my overclock, i tried replacing the TIM on the IHS but its made no difference. I'm thinking the problem is either the waterblock has debris in the fins and its struggling to cool properly or the contact between the die and the IHS has gone bad again which it has in the past when i've been moving my PC between houses. The rest of the loop is cooling fine so i ruled out pump etc.
I figure the easiest way to check is to just pull the CPU block off and bang a stock cooler on to see what temps im getting rather than removing the IHS or taking the water loop to bits. If my temps are around normal i'll know the IHS contact is good and i just need to clean the block out, if the temps are bad it saves me draining the loop and ill just take the IHS off and put some new CPL in there.
I use Realbench stress test to put it under load but i can check any program you guys use if ya used another to get a fair comparison.
Cheers.
Cheers.
