4GB+ VISTA RAM BSOD PROBLEM
20 Feb 2008
hi, can anyone tell me the link to the update for the bsod problem when putting in more than 4gb of ram when running vista
thanks for your help! I am building a new pc for a family member and read that this problem can happen so i want to install this update before i put the other 2gb ram in.
Hi.just install vista 64 today,i got 2gb in already,and brought another Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB).
Do i need to put the extra 2gb in first then update,or the other way round?
And Another Thing,Do i need to change the vottage or something my motherboard is msi
Here My Spec At The Moment:
Os:Window Vista 64
Cpu: AMD Athlon 64 X2 5200+ 2.6GHz Socket AM2
MotherBoard: MSI K9N SLI-2F, nForce 570 SLI, DDR2,
Socket-AM2, 2xGbLAN, ATX, 2xPCI-Ex16
Cpu Cooler: Thermalright Ultra-120 Extreme With Scythe S-FLEX 1200RPM Ultra Quiet 120mm Fan
Psu: Ocz 700Watts
Ram: Corsair 2GB DDR2 XMS2-6400C4 TwinX
HardDrive:2 Western Digital Caviar SE16 400GB SATA2
VideoCard: Msi 8800 GTS OC
Screen:Samsung 22" LCD Syncmaster 226BW
Os:Window Vista 64
Psu: Ocz 700Watts
there should be a sticker on the ram, set your volts and timings to what this says. i had a lot of stability problems until i did this, everything else leave on AUTO
edit: do update the put 4GB in, and your away
Thank for your help,i will try this later.
Hi,I just did a fresh install of vista 64 and Sp1 update and all other updates.but when i come to install Windows KB929777 update,to put 4gb in.i get message saying The Update Does Not Apply To Your System.Does anyone no what this mean?
Yep "It doesn't apply to your system"
As in it' already there as part of the included updates already installed.
