- 23 Dec 2009
- RG8 9
Is anyone pushing more than this whilst playing BF1, to be precise?
ta
ta
How much past?
Aiming for 120FPS if that makes any difference to VRAM - the whole thing confuses me.
For £20, yea I would.I'm still confused so I will re-phrase.
BF1, high/ultra @ 1080p @ 120FPS.
Would you uprade from a 290 @ 4gb to a 390 @ 8gb if it was going to cost you £20 or so to buy and sell.
This isn't true at all.but you literally won't be able to notice the difference between the top texture setting and the one below it at 1080p
Yeah, it is. Certainly during gameplay. The only way you're going to tell the difference is by taking still screenshots and comparing them side by side.This isn't true at all.
Nobody's saying there isn't a difference.Every bodies eye are different, some notice more than others.
If there is no difference in the settings why do the developers bother putting them in.![]()
But if you want to tell me that you're going to notice the difference between this:
And this:![]()
As you run past it in-game, then I'm saying that I don't believe you.![]()
