4K 120 FPS Over HDMI LG OLED TV's Nvidia GPU
27 Apr 2014
EDIT:I guess I should say this ,Thanks for the reply's and I know you are trying to help out and are correct. I made the video with a 2560x1440 resolution,said sharing for fun . I am wondering do you think I am trying to trick people into believing that this is actual 120Hz on a Nvidia GPU thru HDMI without a proper adaptor DP 1.4 to 2.1HDMI or proper GPU capable of such bandwidth. Also the adaptor can not do 120Hz HDR/G-sync
Internet is serious lol
You will need a proper HDMI cable and capable 4k 120 TV ,not sure if Variable Refresh Rate is working or just V-sync
1.No G-sync in game unless you turn off exclusive fullscreen. Then you would lose the 120 FPS and back to 60 FPS.
2.Nvidia control panel enable G-sync and V-sync for the 120FPS
3.Setup custom resolution the same as in the video in the Nvidia control panel
4.Tested on Steam games exclusive fullscreen, may not work with XBOX Game Pass
Games tested in video
Shadow Of The Tomb Raider
Sleeping Dogs
Bioshock Remastered
