4k 32 inch viewing angles vignetting?
sg0
sg0
10 Jan 2013
Need help please. I purchased then returned an asus proArt 329uc because of 11 dead pixels. The monitor was gorgeous except for the pixel issue but I also noticed a viewing angle problem. From my sitting position the corners of the monitor were darker than the centre area. When I moved my viewing angle the edge brightness would change also.
Has anyone experienced this with their 32 inch non curved monitor?
Would it be a deal breaker for you?
It's an IPS panel isn't it? You shouldn't be getting vignetting. I would suggest there is a fault here, or they're using junk panels... but ProArt are usually pretty good.
