4K editing.
Yep thats fine, more than enough grunt.
Another cosideration is what software you plan on using to edit with as all the power in the world won't be much use if the software is not optimised to make use of it.
Not true in video editors. Once you get above a mid-range card then there's not much reward for the extra cost:
A 1060 will be fractionally behind the 1070. I would link to the full results, but it's from a competitor who sells rendering/workstation machines.
I'd be using either something from Adobe or Davinci Resolve, !6gb is the max option but I'm sure if I called the store they could sort something out.
Thanks guys :)
