** 4K & G-SYNC FOR LESS THAN £500!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have made a deal with Acer, that for the first 96 units of their latest 4k2k Monitor with G-Sync we can offer them at £499.99.
Once the first 96 have sold, the price shall increase to £559.99 Inc. VAT so those ordering early can save £60.00 :)
Acer 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:-
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:-
- G-Sync Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (60Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Was [£559.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
This is a great price for 4k with G-Sync, compared to the other 4k monitors it is almost like getting G-Sync module for FREE! :)
We shall also be adding several other gaming monitor lines from Acer as well which will all be 144Hz and also arriving in September. :)
Do you know what resolution those 144hz monitors will be?
