So first things first. I am looking to build a 4K@60Hz Gaming PC aimed at games like Witcher 3, GTA V, BF1. I am also keen on HEVC decoding for 4K Netflix. Got all the peripherals. Budget is up to £3500 and flexible.
I have this so far. Notably I am missing a case, I'm thinking the bequiet! Dark Base 900 when it gets released next month. I also already have a 512Gb SATA SSD to put in it.
What are your thoughts?
My basket at Overclockers UK:
Total: £3,047.86
(includes shipping: £0.00)
Some more specific questions/notes:
I am keen to find real evidence to answer my questions as a lot of these threads on the forums end up yo-yoing between "this is better" "no this is better". Skylake vs HEDT CPUs for example. However, personal opinions are always welcome!
- 1 x Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard= £125.99
- 1 x Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail= £299.99
- 1 x Arctic Silver 5 Thermal Compound (3.5g)= £5.99
- 1 x Corsair Dominator Platinum 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (CMD16GX4M2B3200C= £99.95
- 2 x Asus GeForce GTX 1080 DirectCU III OC Strix Gaming Aura RGB 8192MB GDDR5X PCI-Express Graphics Card= £659.99
- 1 x be quiet! Dark Power Pro P11 1000W '80 Plus Platinum' Modular Power Supply= £199.99
- 1 x Samsung 950 Pro 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive= £239.99
- 1 x be quiet! Dark Rock Pro 3 CPU Cooler= £65.99
- 1 x Asus PG27AQ ROG Swift 27" 3840x2160 IPS 4k G-Sync Gaming Widescreen LED Monitor - Black/Red= £689.99
Total: £3,047.86
- Will the RAM clash with the CPU cooler?
- I am torn between a Z170 6700K build and an X99 6800K build. The reasons I see for going 6800K are more PICe lanes and more cores. I struggle to believe that even 1080s in SLI will be throttled by PCIe 8x/8x? I also have yet to see any real evidence that more than 4 cores is an advantage to games now or within the near (~2 years) future? Are there any reputable sources that discuss this definitively? Bear in mind I have no interest in any CPU intensive tasks, only gaming.
- I am not against upgrading the CPU/Motherboard in the future if there are performance improvements worth buying for.
- The 1080s are a placeholder for costing, I'm not sure which one to get yet
- People say reference coolers are better in SLI, can anyone link to some justification for this? Personally, slightly warmer GPUs but with higher performance seems better to me.
- Any other "silent" case options I should consider. I was thinking a Silverstone FT02, but like the idea of a newer case
- I'm not that keen on water cooling, seems like more faff than I can be bothered with
- I may overclock in the future or now, pretty sure decent air cooling will do what I need
- The Asus monitor looks as good as I can get just now for my application. Would anyone recommend it?
- A while after buying this PC I will likely get a Chord Mojo DAC.
