4K Gaming - Ideal CPU / Platform
26 Dec 2009
North
My cousin is looking to replace his old gaming pc, main use is gaming at 4k with some occasional video rendering.
He was thinking 14600k + Z790 mobo
I suggested the 7800x3d + x670 mobo
Having a closer look it’s closer than I thought. My initial reaction based of reviews I watched a while ago were intels new stuff was a bit crap, power hungry and just rebadged 11th / 12th gen stuff.
I think price is comparable, what would be the better pick for the above use cases or any other suggestions?
At 4K the GPU is everything. The 7800X3D pulls ahead in some specific titles (MSFS particularly off the top my head) and is even in the rest, it is significantly more efficient but doesn't have the multicore performance the Intel chip had for rendering.
I would choose the 7800X3D personally if predominantly gaming.
For a mixed gaming/productivity usage, I'd be more inclined to go B760 and 14700K or 14700 non-K, but for gaming only 7800X3D makes more sense and is likely to have more CPU upgrades. AM5 can also have PCI-E 5.0 SSD without stealing graphics lanes, unlike 12th-14th gen, if you care about that.
A 7800X3D is more than capable in mixed use workloads.
That’s what he has specked, which I don’t like the look of. Seems money is being wasted on motherboard and inefficient places. Just not well balanced.
So for a 4k gaming build he is probably better off allocating more of the budget towards a 4080 super in my opinion.
Any suggestions on a better speck?
cheers that seems better balanced. Ive sent him that list and a similar 7800x3d list both coming to around £2100
personally id get the cheapest motherboard possible in that chipset, as doesnt do anything to performance.
£420 (incl. VAT)
£350 (incl. VAT)
£650 (incl. VAT)
£579 (incl. VAT)
Problem with the 7800X3D in this context - you can get cheaper CPUs which are in the same ballpark for non-gaming use and are pretty close for 4K gaming especially if you are pairing it up with a GPU slower than a 4090.
They are missing 1-2 CPUs like the 7900X3D, but overall gives a good overview.
The problem with those other CPU’s, is you paint yourself into corner and suffer high power consumption for very little gain.
Do you mean Z790? If so, I think you'd be fine, but B760? I would not, since the lower-end B760 boards don't have suitable VRMs for a 14700K. The Aorus Elite also has USB flashback, which you might need for a 14th gen CPU, depending on how recent the BIOS is.
I'm not narrowing it down to anything specific but on the Intel side they are using relatively little power for 4K gaming as you are mostly GPU bound and their idle power use isn't bad. Just leaving productivity/application use to consider.
The bigger consideration is the future upgrade position.
