Which would be the preferred 4k GSync solution, 3x980ti or 2xTX?
I feel like 980ti would be the faster choice in most situations, but not sure on futureproofing...
Both setups are a similar price.
Are you looking to crank up the settings to Ultra with maxed MSAA ?
If you're looking to max 4K for the next 3 years with ANY combination of currently available cards, you're dreaming.
I have never run into a VRAM issue even with 4gb VRAM on my 980s. The majority of games even on 4k use just over 3gb with maxed settings minus AA. The witcher 3 uses 2.5gb on 4k with high settings, no AA, no hairworks. So 6gb will be fine even with 4 980ti's. Even GTA V ultra settings with 2x MSAA was fine and doesnt run into an issue with 4gb.
I wouldn't quite agree with that but I know what you mean. The combination that would is 3-4 Titan Xs, they have the grunt and the vram to be able to handle it, see Kaaps results in the owners thread.
