4k HDMI Splitter
23 Jul 2005
I have currently brought a new LG TV, which I just have one HDMI cable plugged in, as it's behind the wall, I require an HDMI splitter which supports the full 4K HDR 10bit for Xbox one X, are there any about? I can only see stuff for 8bit?
Thanks
Look up the Smartooo stuff on amazon. I think it's a Smartooo 63021 that does it, although can't remember the exact model but sure you can find it.
Thanks, the Smartoo 63021, doesnt seem to support
Resolution: 3840 x 2160p
Refresh rate: 60 Hz
Color depth: 30 bits per pixel (10-bit)
Pixel encoding: 4:2:0 or 4:2:2
Refresh rate: 60 Hz
Should do, you looking at the right device. Have a look at some of the questions and answers on amazon. Plus if it didn't work, just return it.
Does this support sky q 4K 10bit? Not just 8 bit
Answer:
Yes it does I have the Samsung 9000js running at 10bit
By Aaron on 03 December 2017
Does this unit support 4:4:4 60hz at 10bit?
Answer:
This HDMI switch is HDMI 2.0b (18Gbps/600MHZ), HDCP 2.2 and DVI compliant; Video resolution is up 4K2K@50/60Hz(color space: YUV4:4:4, YCbCr 4:2:2), color depth supports 10bit and 12bit
