4k hdmi switch
5 Sep 2008
Karazhan
can anyone recommended a 4k hdmi switch that supports hdr ? for my sony tv , need too run the xbox plus a fire stick through it the xf90 only has two full 4k hdmi inputs.
the other port is taken up by my avr for the arc facility but is old and only does 1080p pass through.
Pretty costly I bet, I also in similar situation, going from 1080p to 4k TV, with two 4k sources. Prior to 4k TV using 1080p hdmi switches that I bought second hand around £40. So for me route sources to TV them optical out to my old non hdmi av pre amp. Use that till hdmi 2.1 av pre amp come out
For you I'd either get new avr or 4k switch you may find latest 4k hdmi hdmi V2 switch to be half the cost of a avr!
