4K HDR capable streaming box/stick?
7 Jan 2009
Hey guys,
So with my Roku 4k stick died on me, I'm now after an alternative.
Ideally what i need is a stick/Streaming box that supports a ton of apps and not tied down to only certain ones? For example i need something capable of installing the "Shudder" streaming app.
I've had a Firestick 4k,and to be honest, I didn't like it,Wayyyyy too many advertisements cluttering the home screen, And it didn't support "Shudder" app to be installed out of the box.
Would anyone recommend a certain new 4K streaming box that's not so well known but good?
i did think about Maybe a Nvidia Shield or Apple TV but i have a feeling they will have a lot of limitations and not allow third party apps to be installed. (Plus they are super expensive!)
What would you guys recommend :)
I know you can side-load a lot of apps with an Nvidia shield which you should look into. Apple would tend to be more restrictive in what you can load going by their other devices.
I mainly use it for Plex, plays every format natively, much faster than inbuilt apps. The 4k upscaling is incredible.
This.
It can be used as a Plex server if that interests you, plus it can play games if needed. Upscaling works well.
