4k hdr monitor?.
10 Feb 2011
If I get native 4k monitor will it perform better then 4k DSR?. If I use 4k DSR with Aliasing off then it looks like that frames are as low as 30fps with other graphics on full. I recently bought a new PC from here as said.
https://www.overclockers.co.uk/tita...a-geforce-gtx-1070-8gb-graphic-fs-002-og.html
Changed a couple of things. I7 6700k,KFA2 EX OC 1080GTX, 16GB Ram but with using 4k DSR and 144hz games still look like 30fps or less. Would native 4k with HDR be the same?.
I am looking for one in the next couple of weeks. I no I said this a couple of month ago but its nearing my birthday now so going to get one with 4k and HDR. Not too bothered what htz it got.
Thanks.
coming from a person who has both 4K 60hz & 1440p 144hz
if you gamed at 60+ before, i dont buy 4K yet.
i dont use my 4K panel for anything other than youtube.. (i also have a gtx1080)
it just dont feel smooth unless you get the fps to 90fps+ for mouse input lag.
Wouldn't use that it's kinda LOW-FI go with a £1000+ HDR tv with a decent crisp panel like a high end sony (i actually recommend the one above mine the X94) or maybe a panasonic 902 or a Samsung 9000 series. nothing below these will be bright enough or good enough compared to the average budget pc monitor. (ps do not buy oled or LG tvs in general as all the HDR ones are terrible for smearing and the OLEDs are not bright enough and have motion judder and slow response for pc input on gaming.)
