Hi guys,
I've just joined and need help on deciding which monitor is the best of the best which I can get for under £1300-£1400 max, the less expensive the better. I'm looking at monitors between 27"-34".
Not sure if ultrawide monitors are any good to me as I'm not a gamer, neither do I do any type of editing apart from the odd photo maybe..... Plus I like watching youtube and iplayer etc and 21:9 is not available as far as I know.
Most of my usage includes browsing the internet, watch youtube, and productivity work such as Word/Excel/Paint.
At the moment I have an 8 year old monitor which has a gloss hard housing over the panel, I really like the sleek look and its easy to clean as well, unfortunatley I cant find any like this apart from a couple Acer ones which I dont really like.
I want to connect my PC and Panasonic DMR-BWT850EB to the monitor so I can watch TV plus my CCTV camera system to the monitor and would like to be able to switch to any, at anytime.
Ideally I would like the best of the best in terms of clarity/refresh rate/ connections etc.
Some I have been looking at are:-
- ASUS PA329Q 32" 4K Ultra HD LED IPS Monitor
- ASUS PB287Q 28" 4K Ultra HD LED Monitor
- HP Envy 27s 4K Ultra HD 27" LED Monitor
- Samsung U32E850R
- Samsung U32E850R
Do you guys know of any others?
Which would you recommend ....?? And Why ??
Pro's / Con's ????
Thanks for the help!
Pro's / Con's ????
