Need some advise i have always console gamed on a monitor and with the new ps4 pro coming out im after an upgrade to a 4k monitor but i cant seem to find one that has HDR and 60hz by hdmi
Yup, maybe go for a nice low input lag 40in TV that has 4K and HDR![]()
Yea looks like thats what ill try and find, any good suggestions?
Budget? I'd also make a thread in Home Cinema section too, some guys there will be lots more knowledgeable
I went with the Philips 43PUT4900 (£280, 4K), and although no HDR it does have excellent image quality for the money!
Will do, erm probably like 500-600 , thats not a bad price for 4k
HDR monitors simply dont exist, sadly. There are 10 bit panels out there, but I'm pretty sure they're still using sRGB, so cant quite utilize the wide gamut that HDR will enable.
Basically, there are no monitors out there that will fully utilize the capabilities of a PS4 Pro.
You're gonna need to buy a TV for that, and even then, there's few very options that have 'true' HDR capability(which is a super confusing subject at the moment), plus they're all fairly large sizes, quite expensive and many introduce a good amount of input lag when running HDR content.
You can of course still get a 4k monitor and still enjoy the resolution benefits. Just make sure to get one with HDMI 2.0 as many dont and only allow 4k/60fps through Displayport.
It's all a bit of a mess right now, honestly.
4K TVs are far too expensive comapred to 4K monitors
Eh? The Philips 43PUT4900 is £279.99 (and 43 inches!!!).
VA too with v good input lag...
