4k or g synk? for gaming?
28 Aug 2013
hello im looking for a 32 inch for gaming? not sure what to get
i currently have a dell 24 inchDELL S2419HN, and getting another one
would like another dell, just dont know which way to go 4k or g sink :}
and still havnt got a good graphichs card yet but i see there are cards that can contoll 3 monitors ?
thanks
If the choice is between variable refresh rate and 4k i would choose VRR anyday. Though many 4k monitors come with basic adaptive sync support. 60hz though, eww(personal opinion).
Don't get a GSync-only screen. Get yourself a screen that is gsync-compatible. Most GPUs these days can control three - or more - monitors.
The screen you want is the 27" Acer Nitro 4k.
My basket at Overclockers UK:
Total: £1,661.68 (includes shipping: £11.70)​
But with only a 4670K I think you will find yourself CPU-limited. I foresee a Ryzen 3700 system unit upgrade.
Which GPU do you have? And which games do you want to play? Even quite a modest card will drive a 4K monitor if you're happy with settings not being Ultra.
blimy :( cant afford that
Problem with 32inch monitors is that pretty much all of them are VA and most of those are pretty bad ones. However people seems fairly happy with the Dell S3220DGF ->LINK<- . If you want to follow the talk about this screen then go HERE. Also as Quartz was asking, what kind of GPU are you running? And do you have any kind of budget?
havnt got one yet really not sure what my budget should be any would take any advice, thanks
that dell looks nice, would go with my other 2
