- 13 Mar 2006
Could you recommend a 4k large monitor - would really want at least 38", probably bigger
Use would be gaming (not competitive FPS), movies, a little bit of photo-editing for printing photos.
Would I be best going for say the LG C2 or even G2 series and use as a monitor - will text look sharp after adjustment? and does it work fine for G-Sync/AMD adaptive sync without issue? Will be linited to 120hz at 4k res (don't think an issue at all if it is).
Am I right in thinking the only QD-OLED panels for monitors out atm are the ultrawide 3440 x 1440 34" ones, no 4k panels?
