Hi,
Several 2014 "UHD" 4k TVs are out now, with HDMI 2.0 ports. Does anyone out there have one? I would really appreciate knowing what kind of resolutions you can push to it from current GPUs.
I have R9 290s, and they do not technically have HDMI 2.0 ports. However the HDMI ports they have do support the necessary clock and bandwidth to push a 4k 60hz signal. I think the situation is the same on the nvidia side.
I have a 2013 UHD TV, and for ~£300 I can get it HDMI 2.0 ports. I will be happy to spend that for 4k60, but less happy to spend it if my current cards will still be stuck at 30hz. I cannot find any definitive answer on whether the TV will accept the signal.
If anyone here has a HDMI 2.0 display I would really be grateful if you could let me know just what you can do with it...
Thanks!
Thanks!
