Has anyone switched from 4K @ 60fps to 1440p @ 144Hz and regretted it? I've currently got a 4K60 monitor which I use for both my gaming PC and extending my MacBook Air (scaled 200% 1080p for Retina-like goodness), and I'm considering getting a 1440p/144 monitor to try out higher frame rates in games. I'm not a competitive player - somewhere between casual and enthusiast - and mostly play simulation games so 144Hz will likely be limited in usefulness but I'd like to have that option around for when I dip my toes into more combat-based games etc (for example, I'm trying to get into Skyrim at the moment).
As a related question, 1440p @ 144Hz is about 7% more pixels per second than 4K @ 60Hz, so can I expect similar performance levels from my 6800XT? If I play games that won't benefit from the higher frame rates, I guess I could drop the refresh rate back down to 60Hz, in which case the GPU only needs to pump out 44% of what it would at 4K meaning I could probably be able to crank game settings?
