Hi, within the next 24 hours I will be ordering the iiyama XB2783HSU-1 monitor, I just want to make sure the 4ms will be good enough for my gaming needs. I play a lot of racing sims and FPS. I only have a gtx770 so there will be no super high frames.
Cheers.
Specs:
Screen Size 27"
Panel Type AMVA
Backlight LED
Pitch Size 0.277 x 0.277
Adaptive Frame-rate Technology N/A
HDCP Yes
Connectors
1 x D-Sub
1 x DVI-D In
1 x HDMI
1 x USB
Position Adjustment
Height Adjustable
Pivot
Swivel Stand
Tilt
Resolution 1920x1080 (Full HD)
Aspect Ratio
Refresh Rate 60Hz
Response Time 4 ms
Brightness 300 cd/m²
Viewing Angle 178°/ 178° (°H/°V)
Contrast Ratio/DCR 5000000:1
Cheers.
Specs:
Screen Size 27"
Panel Type AMVA
Backlight LED
HDCP Yes
Connectors
1 x D-Sub
1 x DVI-D In
1 x HDMI
1 x USB
Position Adjustment
Height Adjustable
Pivot
Swivel Stand
Tilt
Aspect Ratio
Refresh Rate 60Hz
Response Time 4 ms
