4oD Question
9 Jun 2006
Purgatory
Hey
Anyone else here use 4oD? I have a little problem with it. Well I installed it the other day (and so have since rebooted a few times already). But still nothing happens when I click the icon in the tray or when I double-click the program. I can't even find the process in Task Manager. Any ideas?
Firstly, remove it from your startup, CCleaner should do the job. For some reason I think it's under the program name 'kdx' (Kontiki\KHost.exe - all).
Reboot, then: Start > Programs > Channel 4 > 4oD
If that doesn't work, you're on your own :p
...or you could just try re-installing it.
