24 Dec 2012 at 13:12 #1 Casterina Casterina Associate Joined 17 Nov 2011 Posts 852 The 4Pin CPU connector isn't long enough to reach the port on the motherboard, is it possible I can get a extension?
24 Dec 2012 at 13:16 #2 Loxa Loxa Associate Joined 18 Oct 2011 Posts 2,342 Casterina said: The 4Pin CPU connector isn't long enough to reach the port on the motherboard, is it possible I can get a extension? Click to expand... Yes it is , i had the same problem a while back. Bitfenix alchemy do a lot of different colors: http://www.overclockers.co.uk/productlist.php?groupid=1929&catid=2221
24 Dec 2012 at 13:27 #3 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,570 If you only need 4 pin there's a cheaper one here: Cubitek Black Cobra Series 4-Pin ATX12V Extension Cable - 30cm You don't need 8 pin?
24 Dec 2012 at 14:02 #4 T345 T345 Soldato Joined 14 Oct 2011 Posts 5,740 Location Kent Surveyor said: If you only need 4 pin there's a cheaper one here: Cubitek Black Cobra Series 4-Pin ATX12V Extension Cable - 30cm You don't need 8 pin? Click to expand... They look nice
