Question 1)
All of my fans have molex 4pins, if I converted them down via a changer to a 3pin, would that enable me to monitor the RPM on individual fans?
Question 2)
If I had a fan controller with a digital readout.. obviously you couldnt set 4 fans on the same channel to different speeds but if they were all connected to the same one, would you see the RPM as technically they should all be running the same speed?
I ask because having 13 fans in my case, an rpm counter on a fan controller would be pointless if the answer to the questions above was no.
Question 2)
