4x fans on one channel? How?
9 Sep 2009
Notts, England
Ive got 4x fans that are all 0.53A
How do I wire them up for one channel of my controller?
Its a Lamptron 50w per channel
Cheers
You want a 3-pin power distribution pcb or 3pin fan splitter pcb. It's a simple block allowing you to connect many fans to one input. Overclockers don't sell them, so google is your friend.
Cheers, after googling I ended up buying "3 Pin Fan Splitter Cable 4 Way 60cm Black"
Looks to be spot on as I need them for the side fans so the 60cm length is perfect...
Cheers
If all 4 fans are a total of .53A that's 6.36w... no problem
If each fan is .53A or 6.36w then 4 fans are 25.44w... no problem
You need a Koolance 4-Fan Wiring Harness - 3 Pin (CBL-NX006P)
