. Recommended spec for Altium
* Windows XP SP2 Professional or later1
* Intel® Core™ 2 Duo/Quad 2.66 GHz or faster processor or equivalent
* 2 GByte RAM
* 10 GByte hard disk space (Install + User Files)
* Dual monitors with atleast 1680x1050(widescreen) or 1600x1200(4:3) screen resolution
* NVIDIA® GeForce® 8000 series, 256 MB (or more) graphics card or equivalent
* Parallel port (if connecting to a NanoBoard-NB1)
* USB2.0 port (if connecting to a Nanoboard-NB2)
* Adobe® Reader® 8 or above
* DVD-Drive
* Internet Connection to receive updates and online technical support
My spec
OCZ 4GB Kit (2x2GB) DDR2 1066MHz/PC2-8500 Reaper Memory HPC Edition Dual Channel
Samsung SH-S223F 22X DVD±RW/RAM/DL Serial ATA Black Bare Drive - OEM
Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache (2x4MB (4MB per core pair) Retail Boxed
Asus 8800GT 512MB GDDR3 Dual DVI HDTVOut PCI-E Graphics Card
Sony 3.5" Floppy Drive Black - OEM
Western Digital WD2500AAKS Caviar SE 250GB 7200RPM SATAII/300 16MB Cache - OEM
Gigabyte GA-EP35-DS3 iP35 Socket 775 8 channel audio ATX Motherboard
Hi-Power Black 700W 14cm Blue LED Fan PSU - 20+4pin 4x SATA 4x PCI-E
Antec 300 Three Hundred Case
Aren't ATI cards suited for this role? 8800GT is daft if you still wanted Nvidia I'd have gone with 8600's.
.If you are using the machine for CAD work then i would be getting the nVidia quadro cards. You can get the quadro features onto the corrisponding GeForce card (If there is one) but it takes a small ammount of modding.
you do know an equivalent quadro solution costs £1000's more. So the question is what real benefits do the quadro give you?
. Also if it wont make use of CUDA then it may be worth getting a quad core as most CAD software will make use of these. Q6600's are cheap now and would be better than a duel core cpu. Again check to see if the software supports quad core
Ah then in that case i would say that 8800gt's were a bit overkill. My 8600 GTS will quite happily output to two 19" screen @ 1280 * 1024 each. I would recommend getting one of them. Also if it wont make use of CUDA then it may be worth getting a quad core as most CAD software will make use of these. Q6600's are cheap now and would be better than a duel core cpu. Again check to see if the software supports quad core
, its for the boss who has been moaning for ages that his machine is to slow.lol so bunged in gaming cards. :-/ What about memory and CPU ?
I would have upgraded his ram.
