4x512 on dfi nf4 ultra?
2 Sep 2003
Sussex
Ive got 2x512 of g skill pc4400 LE ram and 2x512 pc4000 balistix running at 7,3,3,2.5 at 240 mhtz but ive noticed that since putting the g skill mem in my commant rate has gone from 1T to 2T, is this normal and is i run it at 1T would this cause probs? also is this mem setup usually stable (2 diff types of memory) or would a night of memtest show is this is stable or not? it seems to be fine at the mo but havnt ran memtest yet! :D
Running 1T with 4x512mb simply doesn't work I don't think with 4x512Mb so you're stuck with 2T come what may :) The performance hit is around 2-3% in real world usage so its not awful.
Mixing and matching is usually fine, you might want to run half an hour of memtest test 5 looped or some prime95, just to be sure, but if you're not having any problems then I wouldn't worry too much :)
