- 15 Sep 2009
- Birmingham
I've just bought a HTPC and Onkyo HT5305 amp & speaker package.
The HTPC uses onboard audio and graphics on the Gigabyte GA-880GM-UD2H motherboard.
At the moment I've got three HDMI in's - V+ HD box, PS3 and HTPC
And an output to my LG 32" HD TV
The V+ HD and PS3 are set up OK and on the amps display they are outputting to "PLII" However on my PC I'm struggling to get a decent 5.1 setup. At the moment I'm using mode "Dolby Digital" .
In Windows 7 I've got all the drivers installed correctly and the ATI HDMI Output is down as saying it only supports a maximum of 2 channels, so I've used the custom option to enable pass through so I can have 5.1
When I go back into the speaker set up and test the set up, I'm getting test noises from all speakers
Any help would be really appreciated as all my films are now on the HTPC so would be good to finally watch some of the Blu Rays I had for Christmas
Is there much difference between a forced Dolby Digital and Dolby Pro Logic II output? Would I get better sound output if I was to get audio from optical rather than HDMI? As all my other devices are outputting to Pro Logic II
