So you have one man in a chair with a guitar in a room. You mic up that man and his guitar and record it.
You use a pair of stereo speakers to reproduce that in your own room - there you go, the man and his guitar are perched in the centre of your stereo image. The acoustics of the original room have "coloured" the recording and the acoustics of your own room have coloured the playback.
With a 5.1 playback of that recording, there is no advantage whatsoever, agreed?
So what about a live concert. You have The Eagles stood in front of a sellout wembley crowd, performing away. This is what is going on:
Singer, guitarists, drummer all fed into a mixing desk. A live mix is done and this gets fed out to the zillion watt PA rig ramming sound out to the masses.
Now, the microphones used for the singer arent stereo - its an omnidirectional monophonic mic wired (still in mono) into the desk which is then split into two for each side of the PA array. At no point does the engineer take into account that the singer is moving about - there is NO NEED to - the people in the audience couldnt give a flying one about a stereo image because one simply doesnt exist.
Then, when you take the above into account, does a 5.1 mix even need to be considered? All you have "behind" you is a whole load of screaming fans disturbing your "listening" coupled with some god-awful destructive reverberance. It goes no way to accurately reproducing what it was "like" to be there, it cant possibly do - they dont mic up the seating positions in the stadium!
Why the need for 5.1 then? What is the "aim" of it? I have heard a few 5.1 mixes (indeed, the Pink Floyd 5.1 mixes were done by a guy I know, I think) and all of them sounded reasonable but I still cant see why you would actively choose to listen to one over an accurate stereo recording of the event, fed straight from the live mix!
