Bit of a stupid question, I recently purchased a 5.1 AV/speaker system (LG SR906B) and one of the things the manual wasn't clear on is what the 'distance' setting for each speaker is relative to.  I'm assumming it means distance from the listener or could it mean distance from the TV?
Also, I could use some advice on how best to adjust/compensate for sub-optimal speaker positioning, by which I mean due to the room/furniture layout it is not currently possible for me to set everything up nice and symmetrical. The right speakers (both front and rear) are a bit closer to the TV/Sofa than the left so I'm guessing I could adjust the level (making left slightly higher than right) but not sure if that is a good idea or not. Additionally, the rear left speaker is positioned a bit higher than the others.
I'm aware that the simple answer from audiophiles would likely be "position your kit properly or at least symmetrically" but is there any advice I could heed on making the best out of a bad situation?
