5.1 setup
17 Aug 2005
Swindon
Im after 5.1 for my room but not sure what i should get. A package from argos (they arent a direct competitor are they). They have some sets for £200 look quite nice. Or do i go for a seperate amp and speakers? Id like to be able to use it for PC and TV/360. Would spend upto bout 2/250 cant afford a lot really so not sure which would be better.
Any advice would be great :)
An all in one system will be the best for your bedroom, they have plenty of inputs usually (on decent brands) so you can plug in all your AV stuff. Seperates will be to expensive i would think for your budget.
SONY DAVDZ111 Hi-Fi Surround Sound
This can be found for 179.99 or maybe even cheaper that was just a quick search. I have an slightly different Sony and its excellent, superb sound qaulity and plenty of inputs. plus DTS :)
edit: found it for £154.70 [inc VAT]
thats a bargain in my eyes.
