5.1 speaker advice
13 Jan 2006
Wigan
hi
im looking at buying some Logitech Z-5500 speakers for £187 from a certain internet based store
i no that they shake the earth, but is there anything in the same 'power range' as these or perhaps better for the same price or slightly over.
i dont want 7.1 cos i dont have the space for them, alreaday got 2 of the 5.1 taped to walls.
also does any1 have the z-5500's who can let me no how they are.
*will hopefully be geting Sound Blaster X-Fi Platinum to go with them, currently got sound blaster live 24.
thx :D
joker.
I have the Z5500 and they are awesome, quality build, loud and not to mention the sound quality! be carfull though the sub on this thing is huge! so make sure you have space for it.
Go for the Z5550 you wont be dissapointed, instead of going for cheeper models that dont even compair with the Z5500.
TK
