- 6 Sep 2008
- Near Hull
Hi,
Anyone know a fairly good surround sound system that works with xbox 360?
the ony i'm using now doesn't have optical and the xbox doesn't have 3x audio outputs.
The only way i can do it with the one i have now is buying a console audio adapter, is there a good system that works in full 5.1 with the xbox?
Edit: after a look around i've found you have to use optical to get 5.1, is this true and is their a system for around £100 with optical input?
