31 Jul 2012 at 18:26 #1 delpy8 delpy8 Soldato Joined 7 Jan 2010 Posts 5,114 Location Up NORTH Hi all Can anyone recommend a good fan controller I've see the Nesteq max zero and this is comes with all the cables etc Any other ones that come with sensors and cables for 4 fans
31 Jul 2012 at 18:45 #2 jeff6475 jeff6475 Permabanned Joined 21 Nov 2011 Posts 1,279 The bitfenix Recon is good http://www.overclockers.co.uk/showproduct.php?prodid=CA-072-BX&groupid=701&catid=2331&subcat=189
31 Jul 2012 at 19:22 #3 Tealc Tealc Soldato Joined 13 Jul 2009 Posts 7,392 Location Llanelli From what I've looked at so far with the Bitfenix Recon it has:- 5 temperature probes. 5 channels of 10W each (good for 2-3 normal 120mm fans). Auto setting that'll adjust speed based on temperature thresholds you set. Manual setting. You can adjust speed by approx 100rpm at a time. And of course it's internet connected so you can adjust stuff remotely from your PC. It also a nice blue/white LED screen if you like that sort of thing.
1 Aug 2012 at 09:58 #4 stuie stuie Soldato Joined 29 May 2012 Posts 3,388 Location Dorset Anything with a touch screen, im a sucker for gadets lol, personally im going for the nzxt
1 Aug 2012 at 10:16 #5 delpy8 delpy8 Soldato OP Joined 7 Jan 2010 Posts 5,114 Location Up NORTH Cheers guys I think the Bitfenix looks better than the nzxt
