5.25" I/o bay
6 Sep 2016
My case has six usb on the front probably usb2.
My new motherboard has headers for
5-pin Thunderbolt AIC Connector
USB 2.0 Header (USB_7_8)
USB 2.0 Header (USB_9)
USB 3.2 Gen1 Header (USB32_4_5)
Front Panel Type C USB 3.2 Gen2x2 Header
Existing 5.25" io is this
What 5.25" I/o bay is available that'll allow me to connect up the new technology headers?
I think my motherboard wont have enough usb 2 header to that panel I'll need to blank out unused port on the bay.
Or is there one where it can replace mine so it has power and reset plus usb2 ports and the other new types above?
Motherboard is asrock 650e Pg riptide atx
cases still come with a 5.25" bay?
also doubt theres ever been a manufacturer that ever released updated IO panels even though surely it would be really easy.
youll never need thunderbolt and your mobo probably has usb c etc on the rear anyway.
just connect the heaers you can and don't worry about it.
If you google around (obviously not allowed to post the links here) all I typed into google was front panel USB, it comes up with quite a few options that you could go for, some with multiple USB 2 and 3 ports, front sata ports and built in card readers.
Cant remember the last time I brought a case for myself with any removable front slots, lol, I can remember the last time I brought a case like that for a build for my dad who also wants all of the stuff on the front.
If I'm reading it right, the headers are
Three USB 2 ports
Two USB 3 ports
Two USB C ports
Yes -
2x USB2.0 + a single USB2.0 (this separate one is normally used for internal devices)
2x USB3.1 Gen 1 (also known as USB 3.0)
2x USB3.1 Gen 2 (known as Type-C or USB3.2)
In terms of "using all your connectors", this one would do the job (has a USB2.0, USB3.0 and USB3.2), but doesn't have a Card reader
Akasa still have plenty of other options available though:
yeah that's pretty close, just missing last USB2 and card reader. Guess unlikely find the exact right amount
You'll never find anything with a third USB 2.0 connector, as almost everything uses the the 2xUSB2.0 9 pin connector.
As said above that single USB 2.0 header is designed for internal devices like Fan or RGB controllers, Water cooling accessories etc.
