£50 or less case to fit AIO radiator at the top
26 Oct 2002
Middlesbrough
I'm trying to spec a case for my nephew that can support a 240mm all in one cooler at the top of the case.
Budget is around £50.
He was looking at the corsair carbide spec 05, however the AIO can only fit in the front of it and as a result you lose the 3.5 inch hard drive bays.
The case will be for a gaming pc with a intel 12600k processor.
Kind regards.
Both the AeroCool cases I've bought can mount a 240 up top. I recently bought the AirHawk Duo for my son. Looks great, really quiet and great airflow with those big fans on tick over up front.
