£500 Build Excluding GPU
Yes, but also try this,
Take the RAM out.
Power up.
Power off.
Take one stick of ram and place it in the slot furthest away from the CPU.
Power up, anything?
If not, power off and move one slot closer and repeat moving closer to the CPU every time.
Take the RAM out.
Power up.
Power off.
Power up, anything?
Had to pop out so have only just seen this. Started removing and moving, all are working and the system is booting! Seems that the stick that is noe in the furthest slot away had an issue with.being in the closest slot to the cpu. Currently getting ready to install windows!
