£500 build
YOUR BASKET
1 x Powercolor Radeon R9 270 TurboDUO 2048MB GDDR5 PCI-Express Graphics Card £109.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £65.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
1 x Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail £55.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £41.99
1 x Raijintek Agos Midi Tower - White £39.95
Total : £512.47 (includes shipping : £8.00).
or dropping the mobo down a bit
YOUR BASKET
1 x Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card £129.95
1 x Asus H81M-K Intel H81 (Socket 1150) DDR3 Micro ATX Motherboard £37.99
Total : £504.43 (includes shipping : £8.00).
(You get free shipping :) )
However 270X isn't much faster once 270 is overclocked, so I'd go with the first build as the Z97 chipset is put simply... better
I'm not a fan of those cases, but you'll not get much better than this in my opinion - providing you clock the absolute nuts out of the CPU. Add in a semi-decent third party cooler if you can stretch the budget by another £20.
Well the Neos is also a great budget option, but this has the rubber grommets, two fans etc all of which the Neos doesn't have
Could add a Raijintek Themis as suggested, perhaps there's another case you can suggest? This is the only one I can see really at this price
Mm, there is a black one also I believe - it's probably a bit of a marmite case lol
