5000D Distro
19 Dec 2010
Having problems locating a distro plate for a 5000D, I assumed after they launched the Aqua version with one included it would be available, however that doesn’t seem to be the case.
Can any one recommend a distro plate that will fit the 5000D, either on the front or on the plate next to the mobo tray.
Thanks
I think the Phanteks D140 looks like it would fit in the rear fan mount, it depends if you want to vertically mount the Gpu as it extends down the side of the PCIe bays.
Failing that they do a D120 version which is rectangular and should fit any 120mm fan housing with less ports.
